Can I fax from a Chromebook?
Bryant Gwen
Wysłany: Śro 28 Paź, 2026   Can I fax from a Chromebook?
I use a Chromebook for work and don't have access to a Windows computer or printer. Someone needs a document faxed today. Are there online fax services that work through a regular browser?
Nelson Zaina
A Chromebook is actually a good reason to look at browser-based tools. You don't need a traditional desktop program for everything. https://comfax.com/ describes the web features of Municorn Fax App, so that's one place to start. I'd check that your file format is supported before uploading it. No point getting halfway through and discovering a compatibility issue.
