Betting Odds in Football and Popular Types at Bookmakers
Wysłany: Czw 28 Wrz, 2023   Betting Odds in Football and Popular Types at Bookmakers
What is football betting odds, and what are the most common types of odds offered by bookmakers?
To provide you with an overview of the knowledge of various football betting odds currently available, let's compile all the most common types of odds that betting enthusiasts often apply to their football wagers. Understanding how each type of bet works and its underlying concepts will help you confidently choose the most suitable betting strategy and make accurate predictions about the odds for each match. Let's delve into the details in the article below to gain a better understanding of these popular types of odds.
Watch now: soccer tips pro
Listing the Most Popular Types of Football Betting Odds
Here are the most commonly used types of football betting odds found in bookmakers' listings. Understanding how to play and the essence of each type of odds will boost your confidence when placing bets and help you choose the most suitable odds for your preferences.
Asian Handicap (AH)
Asian Handicap, often referred to as Handicap, is one of the most popular and widely used types of odds in football betting, frequently featured in bookmakers' listings.
This type of odds has a significant influence on the global community of football betting enthusiasts.
The key difference between Asian Handicap and European Handicap is that Asian Handicap offers only two outcomes: either you win or you lose; there is no option for a draw.
Common types of Asian Handicap odds include:
Level Handicap (0)
Half Goal Handicap (0.5)
Quarter Goal Handicap (0.25)
Three-Quarter Goal Handicap (0.75)
One Goal Handicap (Draw)
One and a Quarter Goal Handicap (1.25)
One and a Half Goal Handicap (1.5)
Two Goal Handicap (2.0)
European Handicap (3-Way Handicap)
This type of odds is also popular and widely used in football betting, preferred by many bettors.
European Handicap involves three possible outcomes: Win, Lose, or Draw.
You simply bet on one of these three outcomes. If your bet aligns with the bookmaker's result, you win.
To add variety to this type of odds, some bookmakers have introduced variations such as Half-Time/Full-Time (HT-FT), which allows you to bet on the outcome of either the full match or just the first half, offering more flexibility and opportunities to manage your bankroll efficiently.
Over/Under (Total Goals)
The popularity of Over/Under odds cannot be denied, as many players find this type of odds intriguing.
Over/Under bets are based on predicting the total number of goals scored in a match, and bookmakers provide corresponding odds.
Bettors use their top-notch prediction skills to choose suitable odds. The two main categories are:
"Over" indicates a prediction that the total goals will exceed the bookmaker's set line.
"Under" indicates a prediction that the total goals will be fewer than the bookmaker's set line.
Find out more : betting tips group on telegram
Additional Football Betting Odds Types and High-Level Betting Tips
Draw No Bet (DNB)
This type of bet is straightforward: you select one of the two teams to win, and if the match ends in a draw, the bookmaker refunds your wager.
Both Teams to Score (BTTS)
There are only two possible outcomes for this bet: either both teams score, or neither team scores. Bettors place their bets based on these two scenarios.
Odd/Even Goals
Bookmakers predict the total number of goals in a match as either an odd or even number. Predictions are relative, so bettors with strong analytical skills often excel in making accurate predictions.
Double Chance
Also known as Double Chance bets, these are for those who prefer a safer approach. This type of bet increases the likelihood of winning by allowing for two or three possible outcomes, even though the potential payouts are lower.
Common options include:
1X (Home team win or draw)
2X (Away team win or draw)
12 (Home or away team win)
Correct Score
Bettors predict the exact final score of the match. If their prediction matches the actual outcome, they win. Otherwise, they lose their stake.
High-Level Football Betting Tips
Reasons for Choosing These 8 Types of Odds:
An increasing number of bettors are participating in these 8 types of odds.
The odds offer high potential payouts and a good chance of winning.
These 8 types of odds are straightforward and easy to understand, making them accessible to most bettors.
Experts often analyze and comment on these types of odds, providing valuable insights for bettors.
Additional Betting Tips:
Avoid betting on strong teams blindly.
Focus on selective lower-risk bets.
Don't follow the crowd blindly; use verified information for informed choices.
Take your time to research your two favorite teams thoroughly, understanding their playing styles and strategies.
Consider the form and performance of the teams when determining appropriate odds.
Learn to read the information and statistics on the bookmaker's odds board to gather useful insights.
What is a football tip? See now : what's an asian handicap bet
Football betting odds and the information provided above should enhance your knowledge and effectiveness in betting. Combine this knowledge with advanced tips from football experts to consistently outperform online bookmakers.
Strona wygenerowana w 0,08 sekundy. Zapytań do SQL: 13
